N.B.: These sources snapshots are NOT final versions. The UNA release is in the top-level UNA folder.
UNA drivers are written in linkable assembly code requiring sdasz80.exe (3.0.0, below) and sdasz80d.exe (3.4.0, below, renamed)
UNA Setup is written in 'C', requiring SDCC (Small Device C Compiler), linker, and Z80 library.
The .ZIP files reflect the Mark IV origin of UNA with the M4- prefix on the source (SRS) file name. Sorry.
Required to compile, assemble, and link the UNA sources:
SDCC 3.0.0 [[http://sourceforge.net/projects/sdcc/files/sdcc-win32/3.0.0/sdcc-3.0.0-setup.exe]]
SDCC 3.4.0 (assembler only) [[http://sourceforge.net/projects/sdcc/files/sdcc-win32/3.4.0/sdcc-3.4.0-setup.exe|http://sourceforge.net/projects/sdcc/files/sdcc-win32/3.4.0/sdcc-3.4.0-setup.exe]]
(The above are the Win-32 versions. SDCC 3.0.0 runs significantly faster on Windows-32, and produces better code than 3.4.0. However, a macro capability has been added to the assembler in 3.4.0, so this assembler has been renamed with a “-d” suffix to make it separately available.
[[hex2bin.zip]] hex2bin and bin2hex utilities; source, and Win-32 and Linux-32 binaries are in the zip file.
A “MAKE” facility Open Watcom NMAKE from the 1.9 release. Microsoft “NMAKE” can no longer handle some of the long command lines.
27-Jun-2014
06-Jun-2014
una-1_50-103.zip | 461.1 KiB | 2015/10/31 18:43 |
una-1_50-112.zip | 463.4 KiB | 2015/10/31 18:43 |
una036b.zip | 245.0 KiB | 2015/12/26 10:58 |
una036s.zip | 381.2 KiB | 2015/12/26 10:58 |
una038b.zip | 245.0 KiB | 2015/12/26 10:58 |
una038s.zip | 379.6 KiB | 2015/12/26 10:58 |
una041b.zip | 645.6 KiB | 2015/12/26 10:58 |
una041s.zip | 381.4 KiB | 2015/12/26 10:58 |
una043b.zip | 645.6 KiB | 2015/12/26 10:58 |
una043s.zip | 390.5 KiB | 2015/12/26 10:58 |
