For a reference implementation of this template with the links, etc included - see ECB Bus Monitor
Board Name
<Place photos or renders of the board here>
<Populate this area with a brief description of the board>
Board: Make this a link to a .pdf showing the board layout
Schematic: Make this a link to a .pdf showing the schematic
Manufacturing Files: Make this a link to a .zip with Gerber files
KiCAD Files: Make this a link to a .zip with KiCAD or other EDA files.
<Include thinks like parts lists, BOMs, test software, notes from the board designer, etc in this section.>
Builder's Notes/Comments
Nothing was found.
[n/a: No match]
wiki/templates/board.1460853028.txt.gz · Last modified: 2016/04/16 20:30 by admin
